Jeep TJ pinion angle
Rdouma73
Florida
Hello, I just installed my SYE kit and set up my rear pinion angle. After all tightened up the rear pinion ended up being about 1 degree higher than my driveshaft angle. I was told that it should be about 1 degree lower, but being that it is one degree higher will it by okay, or should i readjust?
Only way to say for sure is drive it and find out.
It should be 1-2 degrees lower, but nothing is going to work better than you going out and driving it and letting us know how it went.
Reactions: ColoJeep
Welcome
There's no perfect preset number.
Your goal is no vibrations.
Reactions: macleanflood
Might also want to check if your axle is centered and pointed in the right direction.
-Mac
Mine ended up being a little over 1 degree above. It's not as common but, I guess, some Jeeps just want to be different. If that is where you are vibration free then it's the right adjustment.
