JL wheels are what, 6.25” backspacing? So you’d need at least a 2” adapter to get them where you could run a decent size tire without rubbing?
I’ll pass on that. That’s a bit too much adapter for me.
They look good though!
Yeah you wouldn't be able to run 35 or larger without rubbing with a 1.5" adapter. But this video was only intended for those wanting to run the 285/70 Rubicon tire.
I used 1.5" Rough Country adapters.
LOL, I am running the exact same wheels and spacer size. I concur, no rubbing at allI put jk rims on my 04 and got adapters from amazon 5 of them for $93 they are 11/4 and I have a 3" lift no rubbing at all.
Nope I have no rubbing at all. I have about 3/8" of clearance between my lower control arm and my tire at full lock.I have
Joey,
Do those run on your lower control arm at all? I’m running a similar setup with SpiderTrax 1.5 on a 285/70/17 on an LJ. I only have a 2.5 in lift and it rubs a little bit at full lock.
RyanView attachment 98839
