Just Springs
BrentW
sharpsburg, Ga.
I have recently bought a 2003 TJ Sport. The previous owner installed a rough country 3.25" lift. It has 2.5 inch springs with .75" spacer. Spacer is only in the front though. The jeep does sit level. (Front lift=3.25, Rear lift=2.5)
I want to change the 2.5" springs out for 3" springs.
I can then add the .75" space back to the front to make it level. (This will give me Front lift=3.75", Rear lift=3")
My question is can i just swap the springs, Or should i just buy a new lift kit with all the brackets, and sway bar links etc.
If you are running adjustable track bars, yessprings can be swapped.
If it were me, I’d check bump afterwards just to make sure you wont run into any problems in up and down travel, along with making sure your shocks are still right for the additional lift provided by the springs.
