Just got this TJ so I’m still learning about the platform. After some reading on the forum I think the current lift on the Jeep is about 4.25 inch front, 2.5 inch rear.
The Front coil plus spacer measures about 16.25 installed. The Rear spring (no spacer) measures about 10-10.5 installed.
I believe this is a Rough Country 2.5 coil lift with an additional 1.75 spacer in the front. Can someone confirm this seems accurate?
Jeep body sits almost exactly level front to back. It does seem to sit about a half inch higher across the entire pass side VS the driver side. Full tank of fuel.
I plan to replace these springs, shocks, UCA, LCA, and bump stops. Wanna keep the Jeep at this amount of lift so looking for confirmation and advice on coil springs.
