Hello!
I have a 2004 Jeep Wrangler Rubicon. I've recently developed a knock which I believe is from the steering box, but it is possible it is from the steering shaft, I just can't tell.
It does this when moving the steering wheel from one direction to the other, but stops once you start turning in the other direction. It does it when at a complete stop so don't think it is any of the other suspension parts. I did put the jeep on stands and could not find any play in any other parts as well. Interestingly, the knock did not happen when the tires were off the ground (so providing no resistance).
Also, it appears a leak has developed at the bottom of the steering box as there was a small amount of fluid there. Only on the bottom of the steering box.
I'm strongly thinking it is the actual steering box, but again I'm not positive so before I shell out the 300+ on a new (rebuilt) box, looking for other opinions.
Thanks!
Thanks!
