'06 LJ. Left rear light wiring. Attempting to install Quadratec LEDs with three (black, green & red) wire housing. Pic is existing wiring. There's a sky blue wire coming out of the back (in the pic it looks connected but it actually snakes inside the hole and disappears in the back of the Jeep), and spliced into the pinkish wire (that's coming out of the harness). From the splice emerges the pink wire, which then connects to the stock light.
Long and short is the left quadratec light is defective (I tested it on the right side, which i know works because the quadratec right light works there, and it didn't work on the right side either). I went to reinstall the stock left rear light and now I can't get the brake lights to work (they work on the right light, which is the quadratec light). Right rear light wiring did not have the sky blue wire and splice; just the three wires and i just had to connect and it worked.
Hope this makes sense and appreciate insights.
