I am pretty sure I read on here that unless you have a long arm kit or a certain height of lift, stock control arms are ideal for the front. Am I recalling this correctly? At what height should you go adjustable? Lastly, does the creak typically come from the upper control arms or should I go ahead and replace upper and lower?
Mine are creaking every time I hit a bump and need to be replaced. I currently have a 4” lift, SYE w/ Adams Double Cardan CV rear drive shaft, and adjustable upper rear control arms.
