So I’m right on the edge, ready to order my springs. This will be for 33x10.5 tires. Looking at two different spring sets. One way is the Light Duty springs from OME, 2932 fronts and 2941 rears, solely for the ride (Advice by DPG based on current vehicle weight). If I add weight in the future I can always change to the appropriate OME springs then. My other choice is the Savvy 3” springs. Given that I do not plan on front/rear bumpers and all the extras, will the Savvy end up giving much more lift than 3” ? This is the main reason why I’m looking at the OME., known lift within a reasonable margin. I only have a soft top and rarely carry passengers and usually only one when I do. I will be installing a 1.25” body lift and 1” MML as well. I'm trying to get myself close to 4” of lift and am unsure if the OME Lights will get there, but am afraid that the Savvy could possibly get way more than I want. I do know I could add spacers to the OME to get there. If so, what’s the most lift by spacer that you would recommend? Does anybody run Savvy 3” springs or know someone that does?
