Lift Complete!
Do you have bumpstop extensions? i recall the JKS bar hits the diff cover and requires 2" bumpstop extensions. Correct me if I am wrong.
Looks very clean!
Thanks! They look great. Good price. Do you think you got more tire clearance? If so, how much? How wide is the flare? Did you do the install? I was reading that there is cutting of the fender involved and not much direction out there on how to do it for DIY'ers.
I was looking at C&C Fab out of AZ. A front and rear set around $750. Look solid though
Mine have zero flare meaning they are flush to the body. Picture what the Oem fender looks like with the plastic flare removed. Any clearance gained is really only whatever the plastic flair removed would net for the most part. I am guessing you gain around 2 inches? There is cutting involved and I did this myself over a two day weekend.
Here’s a good recent post on this topic with good info
Another Tube Fender install
https://r.tapatalk.com/shareLink?sh...nother-Tube-Fender-install.6250/&share_type=t
Sent from my iPhone using Tapatalk Pro
Reactions: JMT
