Hi again everyone,
I just had my passenger side front hub replaced and was on the way home with it when i realized it's pulling significantly to the right as I drive. The faster I drive the harder it pulls. but then if i hit the brakes it pulls hard to the left. Now it should be mentioned that the person who swapped the hub stated that the driver side hub was in need of replacement as well (already ordered now, will be here next week).
My ultimate question is this: is it pulling because it's out of alignment due to the first hub replacement? is it pulling due to one hub being new and the other is bad?and is it pulling hard to the left due to a braking issue such as potential air in the lines?
Asking just so know what i'm getting into before we replace the other hub and it turns out it's a much larger problem?
Thanks in advance once again!
