For which part? Engine? Trans? Diff?Hi, what is the best lubricant I can buy for my 05 with a 6-speed manual? Thank you in advance
Hi, what is the best lubricant I can buy for my 05 with a 6-speed manual transmission for the transmission, 46k actual miles. Thank you in advance
^^^^^^it is stated by jeep that the gearbox oil never needs changing so at 48,000 I personally wouldn't touch it unless you have a slow leak.
Maybe that's the cause of the NSG370's shitty reputation for problems. BMW says not to change the lube in their auto transmissions as well and they are known for developing problems after 120k miles. Those in the know with BMWs change it by then.it is stated by jeep that the gearbox oil never needs changing so at 48,000 I personally wouldn't touch it unless you have a slow leak.
If you got at least the Tough Guard, don't feel like you "settled" for a Fram. In reality it's a very high quality filter and I have 5-6 of them on my shelf at home. It has a 99% filtration efficiency while many of the far more expensive filters only filter to 95%.MOPAR filters is good, I couldn’t find one with COVID, so I settled for fram.
The OP has less than 50,000 miles I think its reasonable to say that the gearbox oil would not need changing in a regular vehicle at only 50,000 unless there were problems. the "never needs changing" only relates to a manufacturers stated warranty miles not forever so should never be taken literally, dont know what they were on TJ,s in USA? I am sure it would be well over 50,000 miles though.Maybe that's the cause of the NSG370's shitty reputation for problems. BMW says not to change the lube in their auto transmissions as well and they are known for developing problems after 120k miles. Those in the know with BMWs change it by then.
Seems like a 6 speed only problem? I am ready to change after only a few days and put in Mopar and fuck the cost!I put Red Line MTL in my 6 speed. One month later I drained the MTL and put Mopar MS-9224 in. The redline made the 1-2 shift very difficult when the trans was cold. I tried Royal Purple in the 6 speed in my old TJ and it was slightly better than the Redline but I would stick to Mopar fluid.
Everyone on forums rave about a product and many noobies like myself just jump onboard for no real reason other than to want part of that rave improvement!https://wranglertjforum.com/threads/so-ok-mtl-in-in-the-6-speed-but.44494/
It’s funny the frequency of similar threads popping up on the same day.
I’m currently using Amsoil and it’s ok. 1-2 isn’t great when it’s cold but that’s normal for a 6 speed. When the time comes I’ll probably put Mopar fluid in it.
I swapped my original OPDA out at 170,000. It never made the barrel of monkeys sound or anything but I was curious to see what it looked like. The gear teeth were worn sharp and the shaft had about an 1/8” of play. The cam was screwed up as well. I was having worn lifter and cam lobe issues as well so I replaced the cam, lifters, and the OPDA. Anyway—the OPDA issue is actually a real thing.Everyone on forums rave about a product and many noobies like myself just jump onboard for no real reason other than to want part of that rave improvement!
This is where I am now learning the term " Jeep TJ Pinch of Salt" Just like people rushing to change out a 14 /15year old OPDA because of a factory defect that was accepted as a fault and remedied in "FEB 2006" lol OHH I have an 05/06 so I must swap for a Crown unit ASAP even though I already have over 100,000k on the original OPDA in 2020 lol,
