On a 97 TJ 2.5 anyone know where to get the little rubber L -tube that goes from the intake to the MAO sensor? I looked in the parts catalog and do not see it. Mine is missing and it is to tight a bend to use vacuum line.
If you can't find one, maybe use a piece of steel tubing, bent to make the angle and then a piece of rubber on each end to make the connection?
If not, you might be able to find a generic vacuum elbow at your local Autozone/O'Reilly/NAPA
