I’m installing an Eaton 30 spline elocker and upgrading to Yukon chrome moly axle shafts. The shafts are cut to fit. I’m not sure since the carrier is different if I can use the old shafts to measure the new ones?
If not should I install the seal, bearing and retainer first and then insert into the axle and measure from bearing race to bearing?
Just worried about destroying a $300 axle shaft by cutting it wrong.
Thanks!
Thanks!
