Misfire codes
Tazjsw
Beacon Falls CT
So I’ve replaced the coil pack the injectors the spark plugs the fuel rail and I’ve flashed the computer and I still get random misfire codes, but the Jeep isn’t sputtering or feel as though it’s misfiring I cannot figure it out I feel as though I’ve fixed everything that could possibly make a misfire. I NEED HELP!!!
What about the cam and crank sensors? If you did, did you use genuine Mopar sensors? All other tend to cause problems.
I didn’t change those. So you think that might be the issue I will have to try them is there a way to see if they are bad before replacing them or no?
