I've been performing some overdue maintenance and TLC on her and as odd as it seems she is running cold.
When I made my way across country 13 months ago I noticed the gauge reading unusually cold so I chalked it up to the thermostat going bad. The conditions at that time were temps below freezing and heavy snow. I pulled out the thermostat the other day (fairly new 195 deg Super Stat) and replaced it with a new 195 deg Stant Super Stat and she is still on the cold side. I confirmed the temps with an infrared scanner and via the OBD reader that displays the stats and both show about 169 deg at idle indoors with +/- 50 deg ambient temps. When I raised the idle to about 2K for 5 minutes the temps dropped to 162 deg. The heat works fine btw.
The only thing I can figure at this point is the fan clutch has internally locked up and is not doing it's job.
Any thoughts ??
Any thoughts ??
