I’m trying to install a new grill and I’ve no nothing about a wench. Previous owner had it installed. How do I disconnect these hoses or whatever they are lol (don’t hate)
You're going to have a hard time changing the grill if disconnecting the winch wiring requires a thread.Ok, I haven’t looked under the hood at all. But hopefully it’ll be easy. Do I need anything special to disconnect them from the battery?
I second this.Wait, what kind of grill?
Well, you could easily disconnect them from the battery terminals, which would be the easy way to do it.
Alternatively, you could remove the plastic cover on the winch solenoid and unbolt them from there as well.
Didn't I teach you anything? All you have to do when you disconnect them is tie a knot in the end and that stops the flow. Works with practically all hoses. They are hoses, right?Disconnecting at the battery would be best. You don’t want those live cables dangling around and coming into contact with the frame, grill, etc while you are working.
Ahhh, it’s a angry grill, few scorch marks will just improve the situation.Disconnecting at the battery would be best. You don’t want those live cables dangling around and coming into contact with the frame, grill, etc while you are working.
For sure will explain the anger.Ahhh, it’s a angry grill, few scorch marks will just improve the situation.
Actually I use a pair of vice grips with no teeth and just clamp her down, works better if there is not enough cable to tie a knot.Didn't I teach you anything? All you have to do when you disconnect them is tie a knot in the end and that stops the flow. Works with practically all hoses. They are hoses, right?
I'm just sad I missed the post about not opening the hood yet when it was posted.
