I have an 04 TJ Sport with a 4.0L & a 5 speed. This was purchased with a salvage title & it may have had some water in places where it shouldn't have had. The rear passenger taillight didn't work & that was a missing ground. The turn signals didn't work & that was solved with a new relay (#EP27C - no LEDs, original lighting). The multifunction connector was fried & that was replaced (Crown Automotive #5183442AA). The multifunction/ turn signal switch was pretty corroded so that was replaced too (#RJ5058003 - without fog lights). I swapped out all of the under hood fuses too with correct amperage on each.
After all of this, the hazards/ flashers still chatter when turned on, which was an original problem. I get the chatter with the key in/ running & the key out. None of the lights, front or rear, are on when the hazards are engaged.
I'm sure I have a missing ground/ 12VDC or a short somewhere under the dash or in a connector.
This is the last thing I need fixed before I can get an enhanced inspection in PA, which is required for a salvage titled vehicle.
Has anyone seen this? Thanks in advance for any help.
