Hi all,
So this has been an issue for a while now but it has just recently gotten worse. It is at a point where I'm actually going to fix it. When I go to start my 01', it cranks for around 10 seconds before it finally catches. Doesn't matter if it is out in the cold or in a heated garage (it has even done it when the engine is around 110 degrees), it won't start like it used to. I have tried pushing the gas pedal down a bit when starting and that hasn't fixed it either. Besides the starting issues, the engines runs perfectly. It's a 4.0 with around 192,000 miles on it. What could this be?
Thanks!
Thanks!
