I was working on my sisters jeep trying to diagnose why her A/C was not cold. I discovered that the clutch wasnt kicking in at all. Checked the fuses, fuse 21 was blown. I replaced the fuse A/C engages and works fine. drive to the gas station and back. A/C doesnt work on the way back. Discovered fuse blew again. I begin checking for shorts. visual inspection reveal the cluster housing the A/C clutch switch, fuel injectors, and o2 sensor? has the heat shrink wrap resting on the exhaust manifold. remove the wrap and the large amount of burnt up electrical tape. reveals bare wires touching. Well there is the short but as I follow the o2 wires to attempt to unplug them i cannot, there is no plug. the o2 sensor is spliced into the rest of the wires, with one of the 4 o2 wires being spliced with the ac clutch switch. My main question is essential if i repair the wires and reroute away from the exhaust manifold is this still an acceptable connection? as it ran with no issues before, or do I need to source a new harness so i have the proper connectors for the o2 sensor, or should i change the wires that are spliced?
