Oil Cooler Line Clip
AndyA
2006 TJ X
Tucson, AZ
What is the part number for this clip? Is it 52002044? It attaches the oil cooler line to the bottom of the fan shroud, so it isn't just swinging around and rubbing against things.
Thanks! Andy
I'm looking for the same item. Mine was a single use item, so going to salvage yard will be a waste of time. Looking up part 5200 2044 on the MOPAR parts sites show a different style of clip. If I find something that works I'll let you know.
Update: Found the following on ebay. (100pcs Car-Line Cable-Tie Clamp Zip Tie Wrap Push Rivet Clip Wiring Loom Harness)
Reactions: AndyA
