P0301 code, now I think a rod is knocking!! '98 4.0
rustyintheoutdoors
Seattle, Washington
Bumping my question again:
I am attempting to chase down a bad misfire that randomly started around a week ago. I daily drive my TJ, change the oil every 3500 miles, and don't beat on it hard.
It's very rough on idle, but appears to be fine when driving, other than being slightly down on power. I have done all the simple things, replaced the distributor, rotor, spark plugs and wires. I swapped cylinder 1's fuel injector with cylinder 2 to see if the misfire would move. It did not. I tested the wiring and connectors to the fuel injectors, they are fine. I did a dry compression test on cylinder 1, and got 89. Tested cylinder 3 for a comparison, it was 150.
I am going to take the valve cover off next to inspect the valves. I am starting to think my 4.0 is just tired out.
Any suggestions would be much appreciated. If it comes to an engine rebuild, I am wondering if I just do an engine swap instead? (Another 4.0, LS, OM606 or TDI swap?)
1998 Sahara TJ 4.0 5 Spd (215k miles)
Thanks in advance.
S and J Engines out of Spokane WA has a good reputation for rebuilt 4.0s. I do think they have a several months lead time, but I would call them.
Crank position sensor?
-Mac
