Hey everyone,
So I was heading out for my first off road outing and the jeep drove without any issue for about an hour and a half. While I’m going down the hill to the entrance of the park the engine dies and I have to pull over.
Symptoms=
No gauges worked
Fuel light came on with a full tank
CEL came on after leaving the key on acc for about a min
No ASD relay click
No fuel pump whirr
When we realized the ASD and the fuel pump were not coming on and switched the horn relay with them to see if we could get it to click, no luck. Out of ideas and lacking cell reception we gave up for the time being. I hopped in my buddy’s jeep and went wheeling with him while we left mine in the field of the 4x4 park. We ended up trailering it back home so we could really look at it in the morning.
After intensive googling we replaced the Crankshaft Position Sensor as others experiencing these symptoms had done but that didn’t help. We check for spark and did a bench test on the coil packs which were good. We replaced the PCM with another Tj and that didn’t help. We were about ready to drop the fuel tank and check the pump when we realized we had somehow we missed checking the fuse box behind the glove box. It turned out that the 10a PDC relays Skim fuse had blown. So we replaced it and tada the jeep was alive again! I ran to the gas station a couple miles down the road and on the way back it dies again going downhill. The same fuse had blown again so I popped it out replaced it and started going again. As I’m pulling in the drive way downhill it dies again. Ok so there is some kind of short is what I’m thinking. I wanted to see if I could just make it back to my house so I stocked up on fuses and attempted to back out of the driveway and I probably went through 4 fuses before I gave up that hope.
So I left it at my buddies and I’m headed over this weekend so we can really dig into it.
I’m looking for any help or direction regarding what could be causing the short or where to look. Can I get a new section of harness for that and just replace it and be done with it or would I need to buy the whole $400 harness kit?
I really want to hit the ground running, come with ideas, parts, and a better understanding so that it doesn’t sit for another week.
Symptoms=
No gauges worked
No ASD relay click
No fuel pump whirr
