C CazzyCazzy New Member Original poster Joined Dec 2, 2023 Messages 15 Location New York Sep 4, 2024 #1 I have an automatic 98 and I just got a 2 inch (more like 3) lift from bds installed. I do have driveline vibes but there’s also this popping sound that happens when I accelerate. Would this be connected to the driveline vibes?
macleanflood I break sh!t Supporting Member Ride of the Month Winner Joined Jul 24, 2021 Messages 11,845 Location Fall Creek, OR Sep 4, 2024 #2 Could be. Probably just something not torqued down correctly. -Mac Reactions: lBasket
Chris Administrator Staff Member Ride of the Month Winner Joined Sep 28, 2015 Messages 79,532 Location Gillette, WY Sep 4, 2024 #3 Could be driveline vibration related, but more than likely it's something that wasn't torqued down properly. What that might be, only you'll be able to know for sure. I'd go through it thoroughly with a torque wrench.
macleanflood I break sh!t Supporting Member Ride of the Month Winner Joined Jul 24, 2021 Messages 11,845 Location Fall Creek, OR Sep 4, 2024 #4 Thread 'Jeep TJ Torque Specs (Complete 1997–2006 Wrangler Guide)' Dec 30, 2018 Battery - Charging System (1997 - 2006) Component Torque Generator Upper Mounting Bolt 2.5/4.0L Engine 55 N-m (41 ft. lbs.) Generator Lower Mounting Bolt 2.5L/4.0L Engine 55 N-m (41 ft. lbs.) Battery Terminal Nut 8.5 N-m (75 in. lbs.) Ground Terminal Nut 8.5 N-m (75 in. lbs.) Harness Hold-down Nut 8.5 N-m (75 in. lbs.) Field Terminal Nuts 2.8 N-m (25 in. lbs.) ...
