2005 TJ, front disc, rear drum. Pulls to the left while braking. Does not have ABS. The harder the brakes are applied, the harder the pull. Newer (less than 1000 mi.) calipers and pads. Right caliper has noticably lower pressure fluid flow from bleeder screw port than left caliper while bleeding. Front brake hoses have been replaced with new but resulted in no change. No visible damage to or crimp in hard lines. IDEAS? @mrblaine
