I purchased a 2006 TJ a few months ago and have been pretty happy with it aside from a few querks. It is a 2.4L 4cyl, with the basic package. I have noticed that (IMHO) the fan is not performing as it should. I have searched the many forums for information and have found out several things. 1. There is much confusion as to how electric cooling fans work. (YES disbelievers, the 2006 2.4L has a factory electric cooling fan. and 2. There is very little information as to how the fan circuit works. Even the factory service manual has gross errors, on one page stating the fan is controled by the ecm, and on another it states it is under control of the pcm. (I have not seen anywhere else in the factory service manual another reference to an "ecm". The wiring drawing of the circuit seems to be in error as well. Let me say at this time I am a retired technician with over 40 years of experience in electronic and mechanical systems. IE: I get it. If anyone has an idea as to what the drawing is supposed to show feel free to enlighten me, but as I see it, it simply won't work as drawn. There is little to no discription of the way the circuit is SUPPOSED to work, which makes it worse. The third thing I might point out, is there are some folks (admittedly trying to help) who offer suggestions that simply arn't correct. For example telling people to bypass or attach jumpers to specific locations can result in a catistrophic failure of a control module resulting in a big buck expenditure. Much of the circuitry in modern automobiles are under the control of control modules which are computers in their own right. The output pins of these can be extremely susceptable to improper voltages and grounds. Without a correct drawing and understanding of how the circuit functions risk is added.
All that being said, I can say that "fundamentally" I understand the circuit as such:
The ETS indicates to the PCM the coolent temperature.
The PCM then determines if the fan is required.
At this point the PCM checks to see if the A/C is active (on) if so the fan should be running
If the fan is needed one of the fan relays is activated. (I really don't know which, the manual offered no help)
The (low speed) relay switches 12v via fuse to the fan motor.
Since the manual drawing appears to be incorrect, I'm taking the stand that it is similar on another lead to the motor. If that is correct, then there are 2 different "feeds" to the motor.
The other side of the motor is tied to ground through a circuit breaker which will trip and auto-reset.
I don't have all my test equipment with me at the present time so I have to take a cautious approach, as I don't want to blow a PCM up. I don't know if the PCM outputs an active low, or high when calling the fan on, and truthfully I don't know if the drawing along with some secret magic would work, since the manual doesn't discribe how it is to work. see attached drawing
