Looking for suggestions.
Symptom - idle will randomly drop (stumble) and run rough. Put in neutral rev a little and sometimes better sometimes not. Completely random. Will run fine, etc... then (usually in traffic) will start to stumble. Only died once. Started right back. Have let run in driveway in gear for 45 minutes and never did it. Drove the next day and did it in traffic.
Have done the following:
-Removed and cleaned TB including IAC.
-Replaced IAC (twice)
-Replaced TPS
-Replaced all 4 O2 sensors
-Replaced plugs (twice)
-Replaced Coil Pack
-Replaced connector to IAC
-Replaced fuel pump
-Checked for vacuum leaks (although that usually raised the idle)
Planning to do injectors next but not sure what else it could be.
-Replaced TPS
-Replaced Coil Pack
-Replaced fuel pump
