Do you guys think it is worth the effort to go from 4.88 to 5.13 gears? I really like how my LJ looks with 35" tires but going up any incline really sucks.
What transmission do you have?
If it’s an automatic, 5.38s are usually the recommendation.
Manual I would stick with 4.88
It's an automatic. I could not find a 5.38 kit for my Dana 30.What transmission do you have?
Edit: you are right. 5.13 would still be an upgrade to the 4.88s. Whether it justifies the cost is debatable. If you want to put in lockers I would do the new gears and lockers at the same time. The additional labor to set up the lockers wouldn’t be much more than just the regear.
I'm actually adding lockers so I figure might as well do the re-gear.That's a relatively small change from 4.88 to 5.13. I wouldn't bother regardless of what transmission you have.
That change isn't big enough to justify the cost IMHO, honestly.
Unless you're getting the parts / labor for a hell of a deal (or doing it yourself), it's just going to be pissing money away for the most part.
I don't think you'll notice much of a change going from 4.88 to 5.13 given how close they are.
I'm changing the axles and installing lockers so it shouldn't be much more to do hopefully. I'm having it done. I try to do most of the work on my LJ but gears is not one of them. I'll ask my gear guy if it is too much I'll stick with the 4.88.That change isn't big enough to justify the cost IMHO, honestly.
