Hello
I explain to you
I heard a noise in the back; direction garage, after being mounted on a bridge, diagnosis: rear wheel bearing HS
So I urgently order on Ebay, and at the same time he changes the bearings of the differential
I take the vehicle back after repair, a few days later: again, the noise again
I go back to the garage, the bearings again, we probably say to ourselves the poor quality of the bearings
I order the MOPAR bearings from Rockauto, assembly and a few days later: rebelote
What is your opinion on the subject?
Should anything else be changed?
Is it due to the bearing of the differential?
I explain to you
