Rear left bumpstop bottoms out first before right side
Is this common for rear left bumpstop to hit about an Inch to inch and a half earlier than the right side when cycling suspension without coils?
The track bar causes the axle to not more uniformly when cycling - it’s possible one side is shifted from being moved by the trackbar - but it is good to leave it in as it shows you what it would really cycle like. Are your bumstops equal on both sides?
If you're lifting at the diff., remember it's not dead center. Maybe it's leaning as you go up?
One shock could be going bad, letting one side raise faster than the other.
