Recommendations for New Rear Soft Top Window
Odd, the rear window should be the same. Craigslist is a good place to find windows, or eBay if someone has a NOS one they are selling.
I would think the same that the rear would be interchangeable between an LJ and TJ.
At this point I've given up on something used. I've already spent more time, gas and travelling only to find duds. You would think someone could.read.the zipper to see if it is stamped with the letters YKK.
Sometimes the reseller/retailer sites aren't 100% accurate. I'd call Bestop directly. They can clarify whether or not the windows are interchangeable. If you find they are, it sounds like that may open up more options for you on the used market - or they can help make sure you order the appropriate new replacement. I did this with mine last year when looking for an extra set of side windows. They had me send them some pics of my top to verify which OEM model it was and even sent me color swatch samples.
Also, if you do continue to look for used options, I've had really good luck both selling and buying things for the TJ on OfferUp and Facebook Marketplace.
Just call Bestop and order a window direct from them. That's what I'm doing to replace a side window.
