So I believe the input shaft bearing is going out on my '99 SE (AX5 trans, 241K miles). When I start moving there is a growling sound. It isn't the throwout bearing.
When I park, put the transfer case in neutral and go through the gears, the growling gets louder the higher the gear it is in. I'm wondering how to fix it. I've never rebuilt a transmission, and have no access (that I know of) to a press. Are there any reputable transmission builders that you would trust, to get a rebuilt AX5 transmission from, or are there better options you can tell me about? I'm located in Utah if it helps.
