Anyone using Rotopax? I'm thinking I really need to get some of these...
http://www.amazon.com/gp/product/B003YBMDRU/?tag=wranglerorg-20
I figured out I'd rather manage my fuel better than carry the extra weight or spend the big $$$ Rotopax seems to think $5 worth of blown plastic is worth. I've yet to run out of gas since I stopped carrying the two 5 gallon jerry cans my previous ORF spare tire carrier could carry. I might leave a couple extra gallons in the small gas container I use for my lawn mower at camp but I won't carry it on the trail.
I never buy gas till my fuel light comes on. Learned last week my fuel light doesn't work. Maybe I should order one - I have prime free shipping. LOLAnyone using Rotopax? I'm thinking I really need to get some of these...
And yes... The price is absurd for blown plastic.
It is until you figure out what the assembly line set up costs to make them. To pump those out is over a 100 grand before you ever mold one item.
Here is a video showing the production line for a blow molded fuel jug. If you make one small change to the item, it has to be done to each mold and copied perfectly.Damn...
My cost estimate doesn't include the ancillary equipment like the line, the extruder for the plastic, raw material conveyor, or the line, just the costs to set the line up to run the molds and the molds. Nor does it take into account the injection molded bits for the screw cap, mounts, or vents. Each of those molds is minimum of 10 grand. If you decide to make a production plastic piece, you best have the design perfect and tested before you go into production. It is a very expensive set up to do and the cost of the item does not reflect the small material costs but the overall cost amortized over several production runs. They will probably have to sell several thousand units before they get out of the red.
I suspect it is an offshoot product from an existing production company.Not to take away from what Blaine said, but I wonder if Rotopax owns their own blow molding equipment or if their products are manufactured elsewhere for them.
They are rotational molded. The good news is the set up is slightly cheaper, the bad news is the manual labor is higher and it looks like they are using a 3 layer system which likely means 3 trips through the oven with additional bits of various polymers added at each heating.
