2006 jeep tj. Has anyone replaces a rough country sye rear seal. Im needing a part # to order. Cant find a part number since rough country doesn’t make them and they are imported. Thanks
You should be able to use either of following. The output shafts on all of the other brands are the same dimensions. I believe the National 3946 seal will also work.
