Hello!
I have a bit of an interesting issue that I don't really know where to start. I have been noticing a bit of a rough idle when I am stopped at stop lights while still in drive. Nothing crazy but the rpm sits at slightly below 750rpm and has drops to a little above 700 every couple seconds then bounces right back up. It feels almost like a mini misfire but I have no codes.
The interesting part is that this goes away completely if I turn my hvac system at any speed or temperature EXCEPT it still idles rough in the foot vents only position. I have heard rough idle when the AC is turned on but this is the opposite and I don't have AC.
My gut says vacuum leak but this just isn't the behavior I am familiar with for a vacuum leak. The rough idle sure but not the rough idle going away when a vacuum actuator is actuated.
Has anyone had this issue or know more about the hvac vacuum controls?
I haven't had a chance to clean the IAC or investigate for any leaks yet and since it is my daily driver I can't pull it apart much during the week.
'98 Sport ~155k miles
