Hello all, I’m sure this has been asked before but can’t find my specific symptoms. I have the 4.0 (non distributor) and over night it began running super rough at idle. About 5 months ago I replaced all kinds of things under hood when I bought it (belt, water pump, thermostat, pulleys, radiator, fluids all around, rear main seal, oil pan gasket, valve cover gasket, spark plugs, check valves, new vacuum hoses, pcv valves, cleaned the throttle body spotless, iac and tps sensors. I,m sure I’m missing something there in that list. The Jeep ran good until now.
I’m not having any trouble starting the Jeep, it starts right up every time. While idling it shakes like crazy, but apply the slightest amount of throttle and it smooths out like it was rolling off the lot new in 2004. The rpm never flutters it starts rock solid around 500 rpm. Driving it has no loss of power at all, but again, let off the gas and we are back to the big block cam feeling. I have seaformed it in the past just to make me feel better but didn’t really need it. Additionally the Jeep is not blowing smoke at all either nor is it throwing any kind of codes. Just for fun I pulled it up anyways to see if had any stored.... nope. I’m running out of ideas here
could the fuel pump be going out ? thanks for the help!
