Higher than normal rpms are caused by a vacuum leak. Your IAC (idle air control) might be dirty and hanging up so it stays open too far which is letting extra air into the engine to cause the extra-high rpms. Or you could have a leak in a vacuum line somewhere between the engine and either HVAC system or the power brake booster which is vacuum power.
Try cleaning your IAC first. Buy an aerosol can of throttle body cleaner and spray it into the throttle body while the engine is running at idle rpms. If you spray the cleaner into the throttle body at IDLE rpms the IAC will suck the cleaner in through itself. Doing so will flood the IAC with cleaner and stall the engine. That's normal and ok, just restart the engine and spray it some more. A fine mist instead of a heavy spray may help keep the engine running. Just don't raise the engine rpms above idle, that will shut the IAC off and the IAC will stop pulling the cleaner through the itself.
If that doesn't help it's time to look for a leak in the vacuum system. Spraying the IAC hoses while the engine is running can help locate the leak. If the spray finds a leak the cleaner will get sucked into the engine through the leak and you'll hear the engine rpms change.
This shows the vacuum system. The vacuum system has a line that passes through the firewall at '2' to connect to the HVAC system. The power brake booster gets its vacuum via larger diameter rubber hose between it and the intake manifold.
