MikeE024 TJ Expert Supporting Member Joined Mar 29, 2021 Messages 4,353 Location Southern Arizona Oct 28, 2024 #41 macleanflood said: What oil are you running? Lot of us are running high mileage conventional oil. Even new RMS can leak on the wrong oil. Click to expand... What wrong oil are you referring to that would cause a good RMS to leak?
macleanflood I break sh!t Supporting Member Ride of the Month Winner Joined Jul 24, 2021 Messages 11,917 Location Fall Creek, OR Oct 29, 2024 #42 MikeE024 said: What wrong oil are you referring to that would cause a good RMS to leak? Click to expand... Generally anything not high mileage conventional. -Mac Reactions: tr21triton
MikeE024 TJ Expert Supporting Member Joined Mar 29, 2021 Messages 4,353 Location Southern Arizona Oct 29, 2024 #43 macleanflood said: Generally anything not high mileage conventional. -Mac Click to expand... Interesting, I’ve been running Redline 5w30 (for the turbo) with zero leaks 8 months. No need to swell a good seal.
macleanflood I break sh!t Supporting Member Ride of the Month Winner Joined Jul 24, 2021 Messages 11,917 Location Fall Creek, OR Oct 29, 2024 #44 MikeE024 said: No need to swell a good seal. Click to expand... Exactly. A good seal. In a modern engine. With a one piece seal. The 4.0 was essentially drawn out on paper in the 50s and we're lucky it doesn't use a rope and graphite rear main. The two piece seal needs the additives in high mileage oil to keep it from leaking. Or at least that's the established forum wisdom. -Mac
MikeE024 TJ Expert Supporting Member Joined Mar 29, 2021 Messages 4,353 Location Southern Arizona Oct 29, 2024 #45 macleanflood said: Exactly. A good seal. In a modern engine. With a one piece seal. The 4.0 was essentially drawn out on paper in the 50s and we're lucky it doesn't use a rope and graphite rear main. The two piece seal needs the additives in high mileage oil to keep it from leaking. Or at least that's the established forum wisdom. -Mac Click to expand... A good seal means not leaking. Mine isn’t leaking so no need to swell it. I’ve read the documented hit-and-miss results of using high mileage and additives to make a good seal for folks who have leaks. Reactions: macleanflood
Rickyd Nevermind! Supporting Member Joined Jan 2, 2020 Messages 7,857 Location North coast,CA Oct 30, 2024 #46 macleanflood said: Generally any seal that is mopar.anything else will drive you crazy -Mac Click to expand... Fify. Oil isn't the issue Last edited: Oct 30, 2024 Reactions: tr21triton and macleanflood
