I’m with ^I've never had one come loose.![]()
I'll do this. Thank you for the photo.I have two wide pieces of self-wrap hook and loop straps wrapped around each rear roll bar. When I run in that configuration like your picture, I wrap it around the roll bar and corner piece. Of course, the soft side against the top. Mine used to come off a lot.
https://www.strapworks.com/2-inch-self-wrap-hook-and-loop-black
Me either.I've never had one come loose.![]()
I use velcro straps used for electronics on the seat belt when not in use. Just velcro around the rear roll bar on my lj and it stops it.The bigger issue for me is the constant flapping of the rear seatbelt straps if the side windows or top is off.
A couple of small bungees that I keep wrapped around the roll bar back there. Works pretty well. Or if you don't like your passengers just rip the seatbelts out all together.The bigger issue for me is the constant flapping of the rear seatbelt straps if the side windows or top is off.
A couple black zipties fixed that for me. My rear seat has been out for years.The bigger issue for me is the constant flapping of the rear seatbelt straps if the side windows or top is off.
Eh, whatever suits you. My solution is simple, it works and the belts are waiting if I need to put the seat back in.If my rear seat was always out, I would probably just remove the seatbelts...
Mine are zip tied to the roll bar simple solutionEh, whatever suits you. My solution is simple, it works and the belts are waiting if I need to put the seat back in.
That was my solution for many years too.A couple black zipties fixed that for me. My rear seat has been out for years.
That's my solution now.If my rear seat was always out, I would probably just remove the seatbelts...
