Starts fine then won't start
Rushman
England
Hello people
I have a issue with my 2002 tj it starts fine then when I turn it off it won’t restart very well and plutters and farts through the air box
It has a cam position sensor fault but I’ve replaced the cam sensor as it was faulty on inspection…. Also replaced the synchroniser….
timed everything up and erased the fault starts up fine then it comes back… and struggles to start
Is it true that the crank sensor will throw up the same fault…. Could this be the problem
I have the same problem. I replaced the ignition, fuel pump and crankshaft position sensor. It will start andrun for a week and then it will turn over but no spark or seemingly fuel.
