Stock coil spring spacers
Aikicj
Clermont florida
It appears my 1999 jeep TJ has 2 inch spacers and the coil springs appear to be stock based on the length. Should the stock springs be replaced and if so what would you suggest. I want to keep the current height. Also should any of the other steering components be replaced to accommodate the spacers?
Wanting to know if the stock springs are ok with the spacer lift.
I bought the jeep used as shown and need help to understand if the stock springs and steering components are ok or if I should upgrade. I have 33in tires, the steering is a little sloppy. Just had an alignment. Overall I am very happy with the existing height.
Reactions: ranger101
Spacers are the cheap way to do it. Ideally you would replace the spacers with the correct length spring.
