I cant seem to pinpoint my problem here. 2001 with a rebuilt 4.0, NV3550, progressively gotten worse these past weeks. I go to start it up, and the rpms go straight to 750, it used to go to 1200 and fall to 750 now it goes straight to it. It got worse, Rpms getting lower and lower each time. Now it will do that sluggish startup and fall to around 250 rpms and barely stay alive. When I drive it around and go to shift my rpms fall so fast its almost like someones killing the motor and it makes my shifts really clunky(if that makes sense). But heres the catch, its not 100% problematic, sometimes it will start normally and idle normaly(rarely) but now it just bogs down under 500 rpm and I have that issue when I push in the clutch. I put new spark plugs when I rebuilt the motor I tried jerry's trick using 1/3 can of throttle body cleaner into the IAC, took it out and cleaned it too. Im not throwing any codes. What am I missing here?!
