98 TJ, 173k 5 sp manual,,starts fine, idles fine about 825 rpm, when driving at the point of shifting and the clutch goes in the rpm's don't fall as much as I would think they should. Coming to a stop sign if you push in the clutch it starts off about 1500 and comes down to the normal idle after about 7-10 seconds. At that point if you are sitting at a redlight and you rev the engine, it immediately falls back to normal idle. Seems like when it's moving the RPMs start out at the higher end and fall to normal,,,if that makes since. Cleaned TB really good, changed IAC with a Mopar part, no change.
Any help would be appreciated
