Purchased a custom switch panel off ebay that looks like this.
I’ve cut out the ashtray insert with a dremel, & the switch panel is almost exactly the length & width now of that hole. Having trouble finding room to mount with switches being up against the trim & air ducts behind that. If I come out vertically flush with the trim bezel it gets in the way of the shifter handle (automatic). I have seen some other posts on here of jeeps with similar panels & switches. What modifications have you done to make them fit??
