which would you rather have a broken tereflex 4:1 or a working 2.72 in your stock 231...if you must have 4:1, save your money and get an atlas, or at least a 241
Why? They are big, expensive, you still need new drive shafts to convert to one, and when you are done, you still have a big heavy case that you can't twin stick. With the average cost of a used one nowadays, you're better off taking a very hard look at an Atlas. (and I'm no fan of the Atlas, they are big, heavy, expensive and not worth it, but if you going to piss over the "not worth it line" and hit a 241, arch your back a bit more and piss on the Atlas)NV241 all the way.
The only other decent option is a flipped Dana 300 with a 4-1 gear set and twin sticks. By the time you find one, convert it and get it working you'll have Atlas money in it.@mrblaine what would you recommend over an Atlas or 241? A buddy just had his 241 blow apart on the highway on his 06 Rubi, so he's looking for a new case. From what he's found, an Atlas isn't much more than a 241. He hasn't looked into other options as far as I know, but if there's something better, I'd like to be able to pass the info on to him.
OK, thanks, I'll let him know that option as well. He'll probably end up with another 241 as the Jeep is his DD, and he was told it would take 5-6 weeks to get an Atlas.The only other decent option is a flipped Dana 300 with a 4-1 gear set and twin sticks. By the time you find one, convert it and get it working you'll have Atlas money in it.
If I blew up a 241 and liked it, I'd try to find another one so I wouldn't have to redo everything.
Was he flat towing?
The odds are 99.99% that he had a front driveshaft that has been chirping that he ignored. When the centering ball froze and locked up, it does so at an angle because the front axle is lower than the t-case. That acts like a big long handle wrench and just twists the case until it explodes and rips the whole left side off of the rest of the case. Forensic examination of the upper double cardan should reveal it locked up solid.OK, thanks, I'll let him know that option as well. He'll probably end up with another 241 as the Jeep is his DD, and he was told it would take 5-6 weeks to get an Atlas.
No, he was driving it, said he heard/felt a loud bang. He pulled over, looked under it, and the case was split in multiple places.
