From a cold start, Im getting a rotational thumping noise from my front driver side when I start moving. Its a Tick-Tick-Tick right as I start moving the car, and then it completely goes away for the remainder of the drive. Its only at low speed right as I pull away from the driveway. Im only getting it for 5-10seconds until it goes away completely.
Things Ive tried:
Checked my drive shaft U joints — first trying to move them and seeing if there is any play, they are tight as a glue-maker's butt.
I jacked my car up and rotated the wheel, the U joints look fine, there is no play. Also, I dont get the thumping at all when I rotate my tires with them in the air.
Checked my ball joints — I jacked the front driver side wheel up and tried moving it laterally to see if there was play in the ball joints. They were tight as well, and aside from being insanely dirty did not look like they were failing.
Could it be my brake calipers hitting my wheel as I drive? I did just replace them not too long ago... seems that the noise might have showed up around that time.
Things Ive tried:
