CaliSteve TJ Enthusiast Supporting Member Joined Mar 29, 2018 Messages 671 Location Southern California, CA, USA May 6, 2018 #1 Am preparing to do the oil pan/rear main seal process, is it wise to consider a new oil pump at this time? 2005 LJ, 117000 miles
TJ2 TJ Expert Joined Dec 9, 2017 Messages 4,047 Location Texas United States May 6, 2018 #2 CaliSteve said: Am preparing to do the oil pan/rear main seal process, is it wise to consider a new oil pump at this time? 2005 LJ, 117000 miles Click to expand... Oil pump is no where near the work area that you need to clean the oil pan. Maybe oil filter.
OP CaliSteve TJ Enthusiast Supporting Member Joined Mar 29, 2018 Messages 671 Location Southern California, CA, USA May 6, 2018 #3 I do plan on the filter change, only have a couple thousand on it but will swap it anyway.
TJ2 TJ Expert Joined Dec 9, 2017 Messages 4,047 Location Texas United States May 6, 2018 #4 I think OPDA is more of your concern if you really want to change something oil related mechanism. The RMS is very sensitive on mine. I changed it but came back in a couple of years.
OP CaliSteve TJ Enthusiast Supporting Member Joined Mar 29, 2018 Messages 671 Location Southern California, CA, USA May 6, 2018 #5 Completely slipped that in my thoughts process thanks for the reminder
