Tips on removing broken tail light screws?
TJ Rubicus
Wiarton, Ontario
Does anyone have a good method of getting the broken taillamp lens screws out of the plastic taillight housing. There is still about 1/8" of rusty screw sticking out but vice grips won't stay on.
Does anyone have a good method of getting the broken taillamp lens screws out of the plastic t/lamp housing. There is still about 1/8" of rusty screw sticking out but vice grips won't stay on.
My go-to has always been when vice grips fail to drill it out with a drill bit. The tail light screws are pretty small though so I'm not sure how well that would work.
Reactions: TJ Rubicus
Yea the vice grips usually work but I cant get a good hold on the broken screws. Drilling will probably result in a new hole beside the old broken screw. Was just hoping that someone might have a magic fix:)
New $19.99 tail light assembly, less headache and a quick fix. You may spend hours trying to get them out and still not save the plastic.
You wont be able to drill out a steel screw from a plastic housing. You are not strong enough to hold the drill steady enough to not have the drill bit walk into the plastic.
Yea we were at that conclusion...I think its time to upgrade to new LED'S
