I have a 97 TJ with the 2.5 4 banger. I've had it for almost three years now, and for the whole time, the clutch has always been on it's way out, but I've nursed it along for as long as I could. This past Winter it started something odd, and I figured that I'm probably not the first person this has happened to on here. On take off, most of the time it shakes some or just slips. When I shift into 2nd, it's fine. I shift into 3rd and when I'm at speed above 2000 rpms, if I lean into it very hard the engine just free revs, clutch slippage. When I shift into 4th, it's even more sensitive above 2000 rpm. When I'm at speed, if I touch the clutch pedal with even the slightest pressure, the engine immediately free revs. In V8 cars with manual clutch forks, you can obviously adjust the clutch engagement point, but this is the first vehicle I've ever owned with a clutch slave and master.
1. Is there anyway to adjust the throw on the slave cylinder? I'm kind of afraid that my pedal is "riding the clutch" and never fully engaging.
2. I was going to just replace the clutch, but don't want to prematurely wear the new clutch if the slave is not adjusted/working correctly.
3. I'm out of work right now so I don't have any wiggle room on funds for this, but I don't want to waste time with cheap parts. Are the Luk clutches and kits good? I thought about getting an OEM Zoom from Summit Racing. What about the EFT brand kits on Amazon?
4. I think I read somewhere on here a while back that the flywheels on these suckers are not exactly flat so you can't just get the flywheel resurfaced. I guess that means I'm buying the flywheel as well?
5.what fluid would the trans and transfer case take? I guess I may as well replace that fluid while I'm down there.
Thanks in advance for the help,
Doug
Doug
