Hi!
Lurked around for a long time, and finally am in a position to pull the trigger on a TJ purchase. My first vehicle purchase so I want to be extra cautious. I am not mechanically inclined as in, I've never had the chance, but I want to learn with this vehicle, but also do not want to spend too much more after purchasing at the current time.
I have narrowed down between these two:
'02 5spd TJ Wrangler X Apex -$13.5k CAD
https://www.kijijiautos.ca/vip/10177548/
'03 5spd TJ Wrangler Rubicon - $8.5k CAD
https://www.kijijiautos.ca/vip/10693982/
One has new mods (seriously check out the post!), nicer interior, and components I would have upgraded anyways. Rubicon axles including rear Dana 44 (is front rubi also Dana 44 or Dana 30/35?) & TruLock w/ 4.11 gearing. One silly concern though is the Pioneer deck being standout for thiefs.
Floorpans and rocker panels need to be replaced due to rust. Windshield frame is rusting slightly. Surface rust elsewhere that buffing can take care of. Frame is mint (supposedly, I haven't personally checked it out yet).
There has been no engine work on this from the previous owner. I do not know if the owner before him had done anything or not.
So I'm expecting as well, I have no idea if all will need to be done, or just some but listing various maintenance items I've seen that need to be addressed on TJ's:
- Thermo/Waterpump/Radiator/Heater Core
- Coolant flush
- RMS, Oil Pan Gasket, Valve Cover Gasket
- Ujoints replacement (how do I check the worthiness of a ujoint?)
- Serp Belt
- Muffler replacement (owner suggested himself doing this eventually)
- Sensors
- Power steering
Air filter, brakes and clutch are good I know that for sure.
Running on 35's for ~5000km without adjustment of speedo. ODO shows 155kkm.
The '03 Rubi, is basically stock but has had pretty much all that work done already. However at 205kkm. The interior is also pretty bland compared to the Apex model. It would just require the mods down the road. It has also had a rebuilt starter, and bigger battery. Alternator, power steering and clutch are good.
For the difference of $5000 CAD, I get all those goodies but immediate concern is the floorpan replacement and then any issues that might crop up with the engine. I've seen floorpans go for ~$70 per side, serp belts are cheap, gaskets are cheap etc., but the mechanic labour time is the killer cost. How easy would it be to do these by myself if I am starting off with no tools or knowledge except for YouTube, and forums.
I am wanting to keep this vehicle for the entire duration of its potential lifespan, but I also need reliability as it would be my only vehicle to take me to work and school.
I would appreciate any help or advice from the knowledgeable folks on this forum!
- Coolant flush
- Serp Belt
- Sensors
- Power steering
