Hi all,
Something has gone wrong after some drivetrain repairs and I thought I would post here before tearing it back down. I have a 97 TJ with a manual transmission and a 4.0 engine. My rear driveline came loose on the freeway and beat the crap out of everything and split my Tcase. So since I had to remove a lot of parts anyway, I did some PM stuff.
Replaced: Both drivelines, pilot bearing, clutch, slave cylinder, throw out bearing, spring clips on fork arm, and installed a used Tcase. After that everything was great for about 200 miles and then I noticed some grumbling in 1st and reverse (driveway speeds) and now its worse.
With the rear axle on stands, clutch untouched, and engine idling, there is a mechanical grumble (like the input shaft on the transmission is trying to catch) and the rear wheels stumble forward an inch or so. With the clutch engaged, everything is fine. So obviously I have something going on in the fork/clutch/slave arena, but again I thought I would get some opinions before I dug in to see whats up.
Any thoughts? Thanks!
